跳转到主内容
Repair guides and support for your Samsung TV.
2606 个问题 查看全部
Samsung tv had large purple horizontal line
Samsung TVs LNT5271FX/XAA
Last February I changed the busted compacitors. Could this be another bad compacitor?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
7条评论:
its not a capacitor. does this happen on other inputs?
完成的
Yes, it happens on all the inputs. It does go away but sometimes it take awhile.
完成的
this problem is most likely the LCD panel.. did you check the flat cable?
完成的
Flat cable? I am not sure which one you are talking about could u be specific?
完成的
most of the time its a flat cable problem ( this is a thin cable or bunck of thin cable's running from the PCB to to glas lcd panel ( your screen) due to heat and dust it is possible the cable burns or ..) or its a t con based problem . i drop a link : maybe it will be helpfull : LN46A530P1FXZA_1.pdf
good luck kind regards,kevin
完成的
显示更多的2条评论
添加一条评论
1个答案
Just for completion sake. Isolated error like the Horizontal line is a loss of signal to the LCD display. This is not a board issue or a ribbon cable issue, but a Failed Gate driver. Those are IC that are mounted on the flex cables bonded to the LCD panel, also called COF (chips on film). Ultimately this is very difficult to fix (if at all) depending on the panel model. For the DIY'er this most often means to find a replacement panel.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jennifer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 361
