跳转到主内容
The Samsung Galaxy J1, released January 2015, model number SM-J100VPP/SM-J100H.
107 个问题 查看全部
Why can't my phone boot up?
It all started when my phone was charging and it was rather lagging, so I proceeded to reboot my phone. However, i could not start up my phone again and the phone was still on the Samsung screen and nothing happened! I am unable to boot up my phone. Someone please help as soon as you can thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
That is a software issue either one of these should work. If you don't want to lose data flash downloaded samsung firmware from sammobile with the matching model number of your phone located in the battery compartment on a label.
Use Odin with the phone booted into download mode and plugged in. Instructions on how to use Odin and flash firmware on to phone are on every download page of firmware from sammobile.
If you don't need to backup data use Samsung kies with firmware upgrade and initialization OR turn the phone off by taking out the battery for a few seconds and putting it back in.
Then hold the power, volume up and home buttons until the white Samsung splash text pops up and immediately stop holding the power button and keep holding volume up and home.
Then it will boot into the recovery menu. And you can use the power button to select and vol up and down to select in the menu. Select wipe data factory reset and reboot phone from recovery mode.
这个答案有帮助吗?
得分 4
2条评论:
When ive done that the wifi appear and i cant log in
完成的
I'm not able to do any of the suggestions:-
Have removed the battery for 8+ minutes;
Won't boot up;
Holding several buttons down doesn't start up;
Screen remains black so not even able to determine whether battery is flat;
The last time the phone was on the indication was that battery was fully charged?
I really would appreciate some assistance.
Thank you.
完成的
添加一条评论
Its FRP lock. either you had to enter the existing Gmail id or you can use FRP bypass techniques
这个答案有帮助吗?
得分 1
3条评论:
Yeah. There are also people that offer frp lock removal using flash / programming / unlock boxes like frp which is sometimes required if bypass techniques without that do not work.
While I have the tools to do this. I don't offer this as a service as its kinda illegal to me but I could be wrong.
完成的
Can someone help me please, after i flash my phone using Odin, it wont start up, i only seen a black screen even if i charged it stil no logo, i dont know if its charging or not there is no pop up on the screen please help its Galaxy j1, please pm me @successemmanuel458@gmail.com
完成的
when i press and hold volume -,power key..for recovery mode
my phone was normaly start...help...please
and i can't update my phone
完成的
添加一条评论
添加你的答案
Brendan Ng 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 18
总计 6,364
