跳转到主内容
修复你的物品
维修的权力
商店
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
5181 个问题 查看全部
Can't hear music playing without headphones
My girlfriend's iPhone won't play any music or snapchat video audio unless you have headphones in. What's weird is that the phone says theirs headphones already plugged in but there's nothing plugged in. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个回答
最有帮助的答案
If it thinks there is a headphone jack still inside this means that the headphone jack is clogged, water damaged or just has gone plain faulty.
You can try cleaning the headphone jack first and if that does not work then you will need to replace the charging port dock assembly.
I tried cleaning it for a few clients. All ended up still not solving the issue so I ended up replacing the charging port dock assembly for them.
You can get the part from here:
iPhone 6 Lightning Connector and Headphone Jack
Repair guide:
iPhone 6 Lightning 接口组更换
iPhone 6 Lightning Connector and Headphone Jack图片
产品
$19.99
这个答案有帮助吗?
得分 2
添加一条评论
Hi,
there can be multiple reasons for this issue,
if the headphone socket was given a rough mechanical stress [Usage of incompatible headphones].
or it might be a software issue [In that case you can try a Factory Reset]. But without a proper diagnosis its hard to figure out..
All the best..
这个答案有帮助吗?
得分 1
添加一条评论
Hi friend,we think it is the problem of loudspeaker,maybe you can go to repair shop and test it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Keney Napoleon 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 3
过去的30天: 20
总计 8,598
