跳转到主内容
宏碁在1997年购买了德州仪器的移动PC部门,从此进入了笔记本电脑的世界。
1680 个问题 查看全部
The Acer Extensa 4120 laptop won't turn On
This a short description of the issue, the battery LED blinking orange for 3-6 sec then it stop blinking for 1-3 sec and changing to green for 1 sec and repeating like a loop, If I press the power button the loop stop and the battery LED change to green for 1 sec after that the loop repeat itself. I checked the power adapter, battery, battery connector and the DC power jack they all ok. Please let me know if anyone have an idea about this issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Try to remove the battery and unplug the power cord. Let it set for a few minutes. Then leave the battery out and plug the ac power back it and turn it on. The battery might be so dead it won't turn on. If it turns on then put the battery back in it. You may need a new battery.
这个答案有帮助吗?
得分 0
1条评论:
Thank you for your respond, I try this technique but it didn't work with this old machine, If the battery removed the laptop show no sign at all and no LED On or blinking. I think something else going on.
完成的
添加一条评论
添加你的答案
Luke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 100
