跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Screen repair touch id
I;ve not done an Iphone 6 screen replacement before and have brought a complete unit, LCD, Digitizer, Camera and home button. My question is, If I swap to use the original home button and LCD back plate with cable will the touch ID function as normal?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Yes as long as you use the original undamaged full home button assembly you should still have the touch ID function. You would loose the touch ID function if you replace the original home button assembly. So as long as you use the original home button assembly it should work.
这个答案有帮助吗?
得分 3
1条评论:
Thanks once I've done it I'll confirm that it worked.
完成的
添加一条评论
添加你的答案
patjoehar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 132
