跳转到主内容
Considered one of Sony's best smartphones, the Xperia Z Ultra is a 'phablet' style device released in 2013.
20 个问题 查看全部
Connecting main flex cable to the motherboard
If anyone has ever done or got any idea how to solder/fix the volume power flex ribbon to the motherboard please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
最有帮助的答案
The Sony Xperia Z Ultra power flex looks to be the same as any other soldered on flex from the teardown pics. The steps to replace are as follows:
1. apply flux
2. wick solder off pads
3. remove flex while applying heat: DO NOT APPLY BRUTE FORCE OR YOU WILL RIP PADS it may help to add leaded solder to the solder points if you are having trouble.
Check out these videos for other devices with similar configurations:
https://www.youtube.com/watch?v=Ia2VkdfX...
https://www.youtube.com/watch?v=Bp78Vl-m...
这个答案有帮助吗?
得分 5
2条评论:
nice answer :-)
完成的
@jimfixer He's getting better.. I may have to stop harassing him ;-) But he's still giving way to many judgmental down votes to others.
完成的
添加一条评论
How to fix strip in sonz1 ultra
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jigme Yoezer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,632
