跳转到主内容
Portable wireless speakers from Logitech released in 2013.
70 个问题 查看全部
My Megaboom won't turn off, it stopped half way through a song
My Megaboom won't turn off, it stopped half way through a song and now I can't do anything with it. It have only had it since Christmas, I don't use it that often, so frustrating. I have tried rebooting it by pressing on/off button and volume down button, nothing happens. I have connected it to my computer - nothing happens..what is going on??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
My ue MEGABLAST wont turn off its fully charged and won't connect to my bluetooth
完成的
添加一条评论
6个答案
最有帮助的答案
I've had a similar problem with my UE boom 2. Found that if stop the music on phone, then turn UE boom off, then turn it back on and restart the music it will work just as normal. If that doesn't work turn your Bluetooth off on your phone( or just restart it). That solved my problem
这个答案有帮助吗?
得分 2
1条评论:
Have had my mega boom 3 for 2 weeks and similar problem. I had to turn off my connection to Bluetooth to get it to disconnect, but can’t get the power button on the speaker to tune off. I have tried pressing the down volume and center top button to no effect. Do I need to return?
完成的
添加一条评论
I had the same problem, I just waited for the battery to die then plugged it in and now it works perfectly fine
这个答案有帮助吗?
得分 2
2条评论:
It sometimes happens. Crazy but yes it should fix once battery drained and recharged. I am waiting as we speak for the battery to drain.
完成的
Will update after I have recharged etc
完成的
添加一条评论
Me too mine cut out halfway through a song. I tried everything to fix it in the end had to wait for the battery to die then it just started normally.
这个答案有帮助吗?
得分 0
添加一条评论
Me too.... I'm sad about the latest round of EU Megabooms. They were better 10 years ago.
这个答案有帮助吗?
得分 0
添加一条评论
I got the same problem, I might be partially to blame as I hadn't turned it on in over a year, battery dead, charged it and forgot about it so it charged overnight, that might be why it won't turn off. I think sometimes early on the battery memory can get confused and it you have to let it die and recharge it, that's what batteries are designed to do, die and be recharged, so a complete cycle of both can reset the memory.
这个答案有帮助吗?
得分 0
添加一条评论
I cannot get my iPhone to find my megaboom in my Bluetooth…I thought maybe it was old technology in the speaker. Any advice to get it to show up? I did fully recharge it…but still doesn’t show.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dunndearman63 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 20
过去 30 天: 145
总计 11,612
