发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
426 个问题 查看全部
"no SIM, or SIM error" when sending calls. Text and Data works.
This morning, i recieved a text requesting a call back. upon trying i recieved this message "No SIM, or SIM error". My texting and data is working fine so this confuses me. Could it be an APN issue?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 3
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
3个回答
已选择的解决方案
Well, i feel dumb. Im using an unlocked Sprint device on T-Mobile network. Switched the network from CDMA/LTE to GSM/UMTS and its working fine.
这个答案有帮助吗?
按维修分数 7
评论:
Ok i was having the same problem, followed this advice and now it's working. HOWEVER, I can't use LTE. What's going on here?
Because the GSM / UMTS setting does not support LTE.
Device limitation issue due to frequency band support. That's why I go for international models of phones to avoid issues like this.
Is there no work around for this? I have a refurbished sprint phone on the TMobile network and switched to GSM to rid the SIM error, but now no data...
添加一条评论
Sorry to revive this dead thread, but I had the exact same experience (Canadian buying U.S. refurbished from Verizon which could do MMS or calls, but not both, though data still worked for the internet).
Here's how I got everything to play nice on my Samsung S7.
1) open up the settings menu on your phone and navigate to “mobile networks”.
2) select “access point names". From here, manually input your carriers .apn information which can be found on your carrier’s website or in a physical store from the staff members there.
3) save those changes by using the three button icon which opens the drop-down menu in the top right corner of the screen and then selecting “save changes.”
4) press back to go back to the first level of the “mobile networks” page.
5) select the option titled “network mode" and choose the option “lte / gsm / umts”. When you select this option, it will ask if you would like to continue this option manually or automatically. Choose “automatic".
Your phone will now swap between network modes on its own, allowing you to use MMS, data, and talk/sms as you would expect it to.
Hope this helps!
PS. The .apn info for Fido was incorrect on their website circa August 2018. All information regarding apn settings was correct, less the bit about the MMS proxy, which should be http://mms.fido.ca rather than the numerical code that they provide.
这个答案有帮助吗?
按维修分数 2
评论:
Thank you for all help, I could really solve my problem, excellent article.
添加一条评论
"NO SIM, or SIM ERROR" is noted in red on my 2nd hand Sprint provider phone.
Voicemail - Call or Message are the only choices that come up on the phone.
I am Canadian who bought on Ebay a Samsung Galaxy S6 LTE and the home company is Sprint from United States. Everything else seems to be working right now but the when a call goes to the cell, it goes strictly to a voicemail that is not retrievable.
The phone does not show as the Youtube video https://www.youtube.com/watch?v=b_7Gvl1X...
The green screen on this video does not even come up on the phone.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Anthony Messer 将永远感激不已
浏览统计数据:
过去的24小时: 15
过去的7天: 83
过去的30天: 354
总计 12,538
