跳转到主内容
任天堂3DS XL 2015在市场上被称为新任天堂3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
369 个问题 查看全部
Where I can buy this 53p ZIF connector?
Hello
My n3DS XL got broken connector from ABXY board to main board. I want to replace it but I don't know where to buy. Does anyone here know where to buy it ?
I include the exact broken connector (mark with red circle)
Thanks for any help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Take it from me, I've tried replacing these ports on a couple other 3DS XL PCBs. It's almost impossible without a heating table, similar to the work you'd do to reball a PS3, PS4, Xbox 1 or Xbox 360. The pins are too tiny and almost impossible to heat back up properly.
My suggestion is to just buy a new board. If this is a project or you're attempting to fix and sell back on eBay then "scrap" it for parts.
If you want to experiment and you have a heat gun, you could try heating the part off the board to see if that works. You'd also need some kapton tape to protect other devices on the board while this particular port is removed. If you don't want to damage this board, then look for a cheap "for parts" PCB off eBay that you can practice with in order to heat it up and remove the part.
Good luck if you attempt to fix it. I'd highly recommend replacing the board entirely though.
这个答案有帮助吗?
得分 1
添加一条评论
Digi Key or Mouser
Search for JAE FA1004SA1-R8000
Edit: Oops. Never mind. I thought you were talking about the little 4-pin one before I saw the picture.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brian Nguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 590
