跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iTunes won't detect iPhone
Hi Everyone,
My phone is stuck on the apple logo. I could only get it to restore, but iTunes won't detect. My lightning cable work. I assume my dock connector works as well since I got it to restore mode. Any Ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Is your lighting cable an apple product? If it is a no-name brand that might be your issue.
完成的
Did you try DFU (Device Firmware Upgrade) mode yet?
完成的
Yes i am using the original Lightning cable that came with. I can't get it to go on DFU mode. I could only get to restore. When I am on restore mode I can't get it to detect on iTunes
完成的
How many drives do you have on your PC. I have too many and sometimes Windows 10 will not detect anymore drives when I connect more on my system. If you have alot try disconnecting any external drives off you system and then try again. If you are using an apple computer please disregard.
完成的
添加一条评论
1个答案
Just because the phone says it's connected by the lightning cable doesn't mean it actually is. I had an iPhone 4s with a similar issue as yours. It ended up being caused by a damaged diode on the mother board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eliel Arredondo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 125
