跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
455 个问题 查看全部
Troubleshooting faulty 3DS motherboards
I have two 3DS motherboards that I'm trying to troubleshoot, so that I can use at least one to replace another that's in a bricked system. One of the MBs causes the well known 'pops and turns off' problem on boot (where a few seconds after being turned on, a popping sound can be heard, and the system immediately turns off). The other board simply fails to boot, with no backlights turning on for either screen (this one does not respond to any of the 'forced' functions, such as L+R+A+Up).
I've been able to conclude that in both cases the problem is with the motherboard, as a third board was able to start with no issues in the 3DS. The cables had been seated several times to rule out those issues as well. In all cases, the SD card reader, nattery, L/R ribbon cables, WiFi card, infrared chip, top and bottom LCD, microphone, and C stick components were shared, so I've ruled them out as being causes. Both F1 and F2 fuses are shown to be working on both boards as well.
Is there anything else I could possibly test to identify a solution? I hate wasting parts if they can be saved, especially the motherboard.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Here are your answers for both PCBs, they're actually fine. Here's the real problem and fix:
  • Pop & Quick Shutdown PCB
    • This is due to the speaker/3D slider flex ribbon having a small nick in the ribbon near the joint. Finish tearing that system apart and remove the speaker ribbon from the joint. I'm 99% certain you'll find a small cut in the ribbon similar to this: Small cut in 3DS speaker flex ribbon
  • No Backlight Boot PCB
    • This is due to a faulty lower LCD. I found (in the XL version at least) that when it fails to boot and sits at black screens & blue power indicator the lower LCD is faulty and needs to be swapped out. Take a working lower LCD screen and try it out to see if that gets the BSoD PCB to boot up again.
I hope this helps getting your two systems running again. Good luck!
这个答案有帮助吗?
得分 0
2条评论:
Both solutions wouldn't be relevant in this case, as I mentioned that changing the motherboard alone causes the issues. If I use a known working board, everything functions fine. If I use one specific board (without any other change in hardware), the backlight problem occurs. Same for the pop / turn off. I've tried both boards between two perfectly functioning systems, and the issue only occurs when they're used.
完成的
Then the problem lies solely in those boards somewhere. Lifted pins, cracked traces, busted ICs, it could be anything. If that's the case then the next best thing would just be to consider them "for parts" boards since they "corrupt" perfectly working units.
完成的
添加一条评论
添加你的答案
Jill 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 993
