跳转到主内容
Screen wont come on after fixing wobbly screen!
I followed the instructions to fix wobbly screen. Everything worked well. But when I switched the macbook on, i hear it startup but the screen stays blank. Could I have knocked something? Anyone have any ideas of what I should check?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Is just the backlight down or whole display?
完成的
Would you give us a link to the procedure you did?
完成的
The whole display is down.
So I followed this......
MacBook Pro 13" Unibody Mid 2010 LCD Replacement
....to link 16. Then tightened the loose screws and put it all back together.
完成的
Have you attempted to connect it to an external monitor yet? That could at least give you a starting point as to where the issue might be.
完成的
添加一条评论
1个答案
已选择的解决方案
Go back to step #8 and reseat the display data cable, examine the connector and the slot. Make sure the little lock tab that hold it in place will throw down. Hook it up to an external monitor to verify that the GPU is putting out a signal.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
George 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 104
