跳转到主内容
Thunderbolt Male to female extension. from MacBook Pro
Hiii
i am in need of a solution where i could connect my macbook pro to a thunderbolt display which is located about 2-3m away from the macbookpro. in the market there are only M-M thunderbolt cable with data/video transfering. as my understanding i need a M-F adapter in order to work this out. any ideas guy??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
You just need a Thunderbolt extension cable like this one:
http://www.ebay.com/itm/Solidmate-Mini-D...
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
You can use the thunderbolt port on the back of the display and not use the thunderbolt cable that is part of the display. http://www9.pcmag.com/media/images/27080...
这个答案有帮助吗?
得分 4
添加一条评论
Loren's reply is the most correct answer. The Mini-DisplayPort solution does not work because the Thunderbolt cable on the Thunderbolt Display passes data for USB, FireWire and Ethernet as well as Thunderbolt. But you can plug in a male to male Thunderbolt cable into the Thunderbolt port on the Thunderbolt Display. Of course, because there is only one Thunderbolt port on the display, you lose the ability to plug in another Thunderbolt peripheral into the display.
这个答案有帮助吗?
得分 1
1条评论:
Could one then use the integrated thunderbolt cable from the display, to daisy chain? Essentially, this would be daisy-chaining in reverse; does it work?
完成的
添加一条评论
添加你的答案
chamikabmi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 16,650
