跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2686 个问题 查看全部
How to get water out from under backlight.
I have an iPhone 6S. My life proof case leaked, and there is water in my backlight. I opened it up and got the water out, there is just water stuck in the backlight. Is there any way to get this out? I would not want to replace the screen since I have Apple Care Plus, and it would be cheaper to go that route. Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I assume you mean 'I do NOT have Applecare'? It is annoyingly expensive but often worth it for mobile devices as you have found out.
Anyway, you are lucky the phone is still working. I would follow an fixit guide to take the case apart, remove the larger components and let it dry out naturally for a longer period, but another old trick is to put it in a container of rice and leave it there for several days where the rice will gently absorb moisture.
A Canon EOS camera of ours was completely(though briefly) submerged last year, but came completely back to life after a couple of weeks 'in the rice'.
这个答案有帮助吗?
得分 0
2条评论:
I meant that I can get it replaces by apple for 100 bucks. I don't want to do this because the only problem is that there is water in the backlight, and I want to try to get that out before paying the 100 bucks.
完成的
I'm pretty sure opening your phone is going to void your warranty as I'm sure apple has implemented anti-tamper indicator measures on their phones.
完成的
添加一条评论
添加你的答案
Dylan McLaughlin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 156
