iPhone won't turn on after I dropped it
Iphone won't working or turn on after i dropped it
and when i plugged it in the charger it doesn't show anything
and there is nothing on the screen
is the problem with the battery or what ?
Dear Mareshall Teach,
Do you hear the charging sound when plugged in?
If thats the case you could just repace the screen, or reconnect the lcd cables and try again .
这个答案有帮助吗?
no i didn't hear anything
Like what Ben suggested, it might be had taken a pretty bad shock on the chip and you try could Hard Reset by holding both the Power/Top button and Home Button for about 15 seconds until iPhone turns on, if it still doesn't work, I would recommend you to visit the apple genius bar if you still had warranty.
are u sure the the problem isn't with the battery ?
The battery going bad is very highly unlikely. If you want you can replace the battery follow the instructions below:
Guide:
Battery Part:
Adhesive Strip for battery:
I dropped my phone hard on the stadium cracked phone but it had a colorful glitch and I couldn’t see my phone my dad replaced the screen but the phone shows no sign of life ? Like it won’t turn on or anything ?
I have the same problem my phone wont charging or turning on after I dropped it
None of the buttons work even the switch and the sound when i plug the phone
My iPhone 5s dont show anything and any solution on YouTube dont work
It have a small hole just under the flash light and heat up at the same place
Photo of the phone:https://image.noelshack.com/fichiers/201...
Please help me
这个答案有帮助吗?
I guess it could be the Power IC Chip that went bad.
I really think that it is the Power IC because it supplys the Power to all of your components and it is very easy to damage when you drop it.
这个答案有帮助吗?
HI my name is abbass kasalany and my iphone 5s suddenly turn on and off and stop didnot charge and nothing on the screen I ve change the screen and nothing happened what the of proplem for iphone plzz give me an answer fast plzz this is my GMAIL GONDABADAO@GMAIL.COM PLZ HELP
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 10,095
Batteries don't easily go bad like that. Does the phone heat up in specific spots and/or does it heat up a lot in a specific spot?
Sounds like a power management ic chip has gone bad from the shock taken from dropping the phone. How far did you drop it and if you know which part of the phone did it hit on first and what surface?
由 Ben 完成的
there isn't any scratch on the phone !! just some small scraatch on the screen protecter but when i remove it there isn't nothing on the phone screen
由 Mareshall Teach 完成的
