跳转到主内容
Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
448 个问题 查看全部
iPad Air 2 Battery won't charge after screen replacement
I replaced my iPad Air 2's screen. It went well and worked for months now with just only a minor problem: when I plug it into a power source, the touch screen jumps around and isn't accurate. It did not bother me too much since I can use it after its charged. Last night came the problem, it won't charge at all. I tried different usbs, different chargers, plugged into a computer, it all won't work. I searched on other forums and someone mentioned that it could have been the connection between the battery and the motherboard. So basically, the percentage of the battery is still showing, and is accurate, but it just won't charge. Can someone please help solve this issue? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi, are you using an aftermarket charger or were you?
Does the battery go past 1%?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yang Wu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 252
