跳转到主内容
Is samsung galaxy s3 neo i9301 motherboard compatible with i9300 LCD
So my samsung galaxy s3 neo LCD display was damaged and so i want to replace my motherboard into another LCD display and frame.
I wanted to know if my neo's i9301 motherboard is compatible with a regular samsung galaxy s3 i9300 LCD display and frame. I have heard different things through research and wanted to know for sure before buying a LCD display+frame or just a LCD display.
I need to know this as the i9301 LCD displays and frames are considerably more expensive than a regular i9300.
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 2
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
1个答案
I took mine apart and the i9301 OLED (not LCD) is completely different.
Best case you might get a washed out grainy picture if the power lines are in the right place, worst case expensive smoke. The critical part is actually the display itself and some have a separate connector on the right hand side with about 18 wires on a 2 layer micro-ZIF connector.
The problem is that the higher resolution screens have more data bus lines (usually these are a variant of LVDS) and you can see this because each one has a ground plane either side of it.
On my S4 mini the bus has 6 "lanes" and on the S3 Neo 10.
You are better off getting the right screen and selling the old one on, if you are stuck PM me and I can sell you my i9301 (used, has minor damage but works) panel for a fair price.
Whats wrong with the old one if you don't mind me asking? as the parts on it can be recycled and for my purposes some OLED damage may be acceptable as long as some of the screen shows correctly.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Martin Howard 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 7
过去的30天: 19
总计 1,770
