跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2573 个问题 查看全部
iPhone 6S no service after replacing the charging port
I replaced my iPhone 6S charging port and now it shows that it has no service. I have tried a couple different charging ports from different sources and I get the same thing. What could be causing this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
3个回答
最有帮助的答案
Did you connect the small black coax antenna cable that's attached to the charging port? I believe that's the wifi antenna, but you haven't specified which service you aren't able to use on it. Also, if you have attached said cable, is the connector on the board still completely attached? You may have dislodged the solder points if you ripped it off half-hazardly.
Other than that, I have seen only one time before when the antenna at the top left of the board came undone for no good reason. You'll have to the the entire board out to see if it's attached, but it's worth a shot if nothing else works.
One more dumb question, you haven't put it in the microwave recently, have you? I'm not trying to be a dumbass by asking that either. I had someone come to my store with reception issues on a 6S and we, eventually, figured out the him putting it in the microwave caused all of his issues.
这个答案有帮助吗?
得分 4
添加一条评论
If you have a microscope, or other means of magnification, check to make sure that there is no adhesive or other debris in the FPC connector on the board.
Recently I had the same issue after the same repair, and there was a little adhesive from the charge port we removed that went over two pins. These pins were part of the antenna circuit that integrated with the baseband. One of the pins was also on the power rail, so after clearing out the debris the gas gauge operated correctly and the battery life was restored to normal.
Hope this helps a little bit.
这个答案有帮助吗?
得分 0
评论:
I'm having the same issue but theres nothing in the connector, is there anyway the board could get damaged?
完成的
yes board could get damaged.
完成的
添加一条评论
i had the same problem and only original part are working, it needs to be ORIGINAL
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Jon 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 12
总计 6,684
