跳转到主内容
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
Chronic Sound and Airport Failure
PowerBook G4 Aluminum 17" 1.5GHz 2003-2004
A little while back I decided to purchase two PowerBook G4 17" models for spares, and made one aesthetically pleasing functional model. But 1/20 times the sound will work, which bothers me, but it doesn't bother me as much as the fact that it will not connect to either my 802.11B/G/N network or my Airport network. It also will not power on with an official Apple charger, and I have to use a really bad Amazon charger.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
First I would replace the DC-In board. Here's how: PowerBook G4 Aluminum 17" 1-1.67 GHz DC-In Board Replacement
Here's a source for the part: http://www.ebay.com/itm/New-Apple-PowerB...
Next go into the system profiler and see if the airport card is being seen. Hook up to a hard wired ethernet cable and see if it will log on to the internet. Let us know your results.
这个答案有帮助吗?
得分 1
3条评论:
Ethernet works, and it recognises the AirPort Card, but the Airport card doesn't recognise my Asus router nor my Aorport network consisting of some old pre-G4 Quicksilver Airport Base Stations
完成的
Did it ever recognize then or is his something new?
完成的
This is nothing new, I've always had trouble with this machine connecting to my wireless networks
完成的
添加一条评论
添加你的答案
Andrew Mattera 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 148
