I need bios rescue password 2012-01-01
hi i need BIOS RESCUE PASSWORD for my asus m80ta
i test ABLDABLA and not work for me plz helpppp
ABLDABLA (NOTE: must be all Caps)
这个答案有帮助吗?
if AZERTY keyboard : it's QBLDQBLQ
Parfait fonctionne sur x552mj
Hi All
If you can find the older topics, you can find the solution, anyway reshare again
Try this method, turn on the computer and access BIOS
Please visit this link below.
https://pastebin.com/raw/L3c3rySj
Subtract current year and get the password
e.g.
2019 - 10 = 2009
2018 - 10 = 2008
2017 - 10 = 2007
.. etc
For example:
这个答案有帮助吗?
2007-01-01 ABLDABLA igot for 2012/01/01
这个答案有帮助吗?
2012-01-07 please
Code worked for Asus X551M 01/01/2012, thanks
Disconnect the cmos battery from your computer then re plug it, this will reset your bios.
这个答案有帮助吗?
Some of us don't have battery inside ;)
hi same problem with 2012/01/01,
anyone can help?
thanks
para los que aun no desbloquean aca esta el unlock x fecha https://www.biosbug.com
goathack vzla
这个答案有帮助吗?
No funcionoa, al menos en mi transformer T200TA no sirve el pasword generado con el dia 2012/01/08
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 7,908
12条评论
hi i need BIOS RESCUE PASSWORD 2012/01/04
=== Updaten (19-10-17) ===
由 kadir 完成的
由 kadir 完成的
Didn't solve the problem
由 Ernesto Ibasco 完成的
Same problem here, ABL… Password for 2012-01-01 not working.
Any other solution?
Just want to come in bios so we can install new Windows, set boot to USB..
由 tibor.lipovec 完成的
No didn't fix it and I forgot the master password on Asus laptop
显示更多的7条评论
