Usb boot freezes three quarters through boot
We upgraded to a ssd and found that it run old windows, but we erased it and we boot using a usb,but it stays at three quarters.
If this helps the ssd is mounted with one screw but will change soon
En una Macbook, tienes que formatear el disco nuevo necesitas tener presionado Comando + R, para que te salga los discos y particiones que tengas, si no te aparece necesitas el USB o disco de instalacion para que lo puedas ejecutar.
Saludos
这个答案有帮助吗?
Translation ..........In a Macbook, you have to format the new disc need to have pressed Command R, so that it goes out for you the discs and divisions that you have, if it you does not appear need the USB or disc of installation so that you could execute it.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 70
