跳转到主内容
电脑制造商联想所生产的台式机的维修和支持指南。
97 个问题 查看全部
no sound on ibm thinkcentre m52 8212-1yu
Hi! I just got one of base IBM ThinkCentre M52 computers (8212-1yU).
Thanks in advance for your time and help!
This computer has windows 7 (32-bit) and Intel Pentium 4 CPU 3.00 GHz.
Under Device Manager, I see the following entries under "Sound, video and game controllers":
• High definition audio device
When I go to Control Panel --> Sounds and Audio Devices, it says "No Audio Device"."speakers not plugged in" the default device is the digital audio which is working but no sound out of the inside speaker
the sound card is built in on the motherboard, I checked Lenovo support site
There is no sound on this PC, though there are outlets for mic and speakers. I tried hooking up my headset, but here is no sound.
Micrsoft's Mr. Fixit utility
Any help would be greatly appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
In the device properties can you change the default device from digital to analog duplex ?
这个答案有帮助吗?
得分 0
添加一条评论
Try right clicking on the spear icon next to the time and date. Select Play Back Devices and check the defaults. the speakers may not be enabled. You should see a sound bar indication sound. The other thing is to update the drive for the audio system through Device Manager, if it comes back and says the best driver is already installed, then delete the device and check remove driver and then do a scan for hardware changes, this should force a fresh driver to be loaded.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
revolt25012011 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 10
总计 1,012
