跳转到主内容
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
445 个问题 查看全部
Help identifying the CORRECT Logic Board Part #
MacBook Pro 13" Retina Display Late 2013 -...
Howdy folks! A customer of mine has a MacBook Pro who's logic board that was damaged by water. A water bottle spilled in her laptop bag . The red water indicator under the trackpad ribbon connector is positive for water damage. I am looking to properly identify this board so I can order a new one. I thought the BEST thing to do is share a picture of her back cover so you smarties can see for yourselves what model and other machine specific identifiers.
I'd also like to ask if you know where to get parts from a REPUTABLE distributor.
THANKS in advance!
Glen
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个回答
已选择的解决方案
Here is your part.
MacBook Pro 13" Retina (Mid 2014) 2.6 GHz Logic Board
MacBook Pro 13" Retina (Mid 2014) 2.6 GHz Logic Board图片
产品
$269.99
这个答案有帮助吗?
得分 3
评论:
I used http://www.everymac.com to ID the computer via serial number.
完成的
Apple Part #: 820-3476-A
@ilabbe - once you do identify a machine, it's best to correct the icon so they can get to the guides
Here's the replacement guide: MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement
完成的
Correct the icon? I'm not sure what your mean. But THANK YOU GUYS for your help!!!
完成的
Ahhhhhhhhhhh!!!!!!! <Screaming like a frightened 5 year old girl> $700 dollars??????? My customer will fall over backwards, BUT... now that I know the part number I suppose I can look elsewhere.
Thanks again!
Glen
完成的
添加一条评论
You might want to finish your profile so you can establish yourself as a professional with iFixit to get better pricing. Click on either my icon or Johnathans to look at those profiles.
这个答案有帮助吗?
得分 3
评论:
Thank you Mayer!
完成的
Yes, that price is way out of line and not at all in line with current prices on the marketplace. I would contact customer support and ask for a price update after you are set up as a reseller. But as you may know, other part sellers sometimes put an artificially low price on a part and then when you go to buy it find it is out of stock. Here's an example : http://www.powerbookmedic.com/MacBook-Pr...
完成的
添加一条评论
添加你的答案
Glen Comstock 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 2
过去的30天: 12
总计 1,227
