跳转到主内容
Model A1320 / 8 or 16 GB capacity
156 个问题 查看全部
went through the washer, now battery won't charge
My iPod was soaking wet when it came out of the washing machine, and I tried to dry it out in rice, but it still only works with the charger. As soon as I unplug it, it stops working. Anybody know a good way to tell if it really the battery or instead related to the charging circuit? Or something else?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Thanks for the reply. Here's what I found- got the unit apart, found the solder connection where the battery attaches to the mainboard, and measured voltages with the unit plugged in and on. 3 solder pads, from top (as in closer to the top of the iPod) measure as follows:
top=ground.
top-middle= changes depending on what is displayed on the screen.
top-bottom= 4.11 Volts.
Believing that the 4.11 is the charging voltage and the top-middle voltage is the regulated output to the mainboard.
Unplugged the unit and the 4.11V disappeared (duh) and the top-middle voltage went to 0 V.
Based on this, it appeared the batter was getting power to charge but not charging. I ordered a new battery and soldered it in (not for the weak of heart of shaky of hand) and this fixed the problem. Top-bottom now measures 3.81 V, which makes sense if the battery is charging now. I did not wait for the batter to charge to see what the V would be when fully charged. Hope this helps somebody else! thanks all!
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Only
disassembly and inspection can answer such questions. Look to see if there's corrosion or burn marks on the logic board that's your problem. If not inspect the battery could be swollen (indication of short) or damaged.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
这个答案有帮助吗?
得分 1
1条评论:
Good on you! for solving your own problem, and sharing it with others.You could change your comment to an Answer if you wish
完成的
添加一条评论
添加你的答案
oldchevytruck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,197
