跳转到主内容
所有的苹果便携式平板电脑的全面维修手册。维修过程可能需要加热以及细心的撬动。
5755 个问题 查看全部
How to recover photos from disabled ipad?
hi,my ipad has been disabled and i want to recover all my photos in it. i also dont know the password of my appleid i've tried to reset my password but no use, it has not been reset. so WHAT should i do??? please help!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
4条评论
My iphone 7 is disabled and I want to retrieve the videos and photos and I didn't get a chance to back it up to the cloud is there any way that I can get it backed up while it's disabled???
完成的
Hiya, I have an old iPod 5th generation I believe and I broke the screen but the photos in it are very important to me. I dont have much access to the iCloud storage. Is there still a way I could get the photos? Please help T ^ T Email me @ Sonic1.amy2@gmail.com <3
完成的
I just got an email says find my iPhone has been disabled and all of my photos gone,
how do I fix that please
完成的
i want to recover photos from disabled i pad2
no backup on itunes
完成的
添加一条评论
2个答案
已选择的解决方案
Hi, if you have already reset the device, then your photos are gone.
Unfortunately there isn't a way to bypass the disabled screen, unless you connect it to a computer that the iPad has been connected to and backed up to before.
If you don't know your Apple ID or password, then your device will be iCloud locked and there isn't much you can do unless you know the details to it.
这个答案有帮助吗?
得分 2
2条评论:
How about contacting Apple?
完成的
Apple need proof of purchase usually, even then there are times where they can not help.
完成的
添加一条评论
when you lose or accidently delete some photos, you definitely want to get them back. If you have made backup with iTunes or iCloud in advance, you can retrieve the deleted photos by restoring your iPhone from iTunes or iCloud backup directly, but the backup will replace all the existing data and settings on your device. There are some ways to recover photos on iPhone:
1.Recover Deleted Photos in Recently Deleted Folder
2.Retrieve photos directly from iPhone,
3.Recover your pictures from iTunes backup
4.Retrieve your photographs from iCloud backup.
Then if you want to recover deleted photos without losing anything, you can’t miss Fonedog Toolkit for iOS. It is one professional iOS data recovery tool that can help users retrieve deleted data from iPhone directly, or extract data from iTunes/iCloud backup effortless. It has some easily steps.
Step1: Download and Launch Fonedog recovery.
Step2: Select files to scan.
Step3: Recover deleted photo on iPhone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jasmindeep 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 31
总计 42,167
