跳转到主内容
The D-Link DIR 600 (also known as the "Wireless N 150 Home Router") is a wireless router sold by D-Link. It supports the 802.11n Wi-Fi standard, which means it can achieve transfer speeds up to 150 Mbit/s.
3 个问题 查看全部
Internet is not working through wifi
When the wan cable connected to laptop it works . internet works fine but when it connect to the router internet is not working.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
I have the same problem and I have tried the below steps but still I am facing the same problem.
完成的
添加一条评论
1个答案
1. Reset the router (reset will set your router to factory default setting, so you will have to configure your wife again)
3. Connect WAN cable (Internet line/connection from the ISP) to the yellow port
4. Connect your laptop to the WiFi and see if internet is working.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chetan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 2,397
