跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
401 个问题 查看全部
Why is my engine smoking and shaking
I pulled out to turn from a red light and I kind of gave it some gas and the check engine light came on. Then, the car just started shaking, so I pulled over to a close gas station and sat a while with the car off. Then I tried to start, but it wouldn't, so I tried again, and it started but only stayed on for a few seconds and started smoking and turned back off. Last week, I went to turn it on and it shook very hard and started smoking again, and I just went to the car to try to turn it on and the car is dead.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个回答
最有帮助的答案
Most likely is a major failure such as a thrown rod. From your question I can see that you're not a mechanic. Have it towed in for a major overhaul and be prepared to spend some serious money to get it fixed.
这个答案有帮助吗?
得分 4
评论:
+ agreed. Could be timing chain, head gasket, rod, crankshaft, or any number of other things. Take it to a mechanic.
完成的
Excellent answer +
完成的
添加一条评论
suggest to buy CARMD can order online its very helpful will tell u whats wrong with ur car if anything wrong with it and it will tell what to fix and alot cheaper to repair too .. just a suggest ..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
prettyboytmty 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 6,352
