Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
3369 个问题 查看全部
Did corrosion form after I successfully used a bag of rice?
My iPhone 5 got stuck in my bed sheets and .went right in the washing machine..!
I used a bag of rice and after 24 hours, the phone was recognised by iTunes. But the day after, it stopped being recognised.
Does the fact that it was recognised at first mean that the phone is still recoverable?
Is that corrosion that formed on the motherboard?
I removed the EMI shield and use Isopropanol 99.9% with a toothbrush but it didn't help.
How am I supposed to get rid of corrosion?
Add a comment
Android 维修工具包
一个新的屏幕或电池就在一个套件之内。
现在开始购物
Android 维修工具包
一个新的屏幕或电池就在一个套件之内。
现在开始购物
1 Answer
Unfortunately, sometimes it is irreversible and it sounds like you have done pretty much as much as you can. Some say rice shouldn't be used as it can deposit more minerals than just water itself (starch etc.) which can contribute further to corrosion.
Personally with a water damaged device I would tear it down as much as possible and use a combination of Isopropanol 99.9%, time (to dry naturally) and patience, remembering to avoid putting power through any part of the device until you can be fairly certain no moisture remains.
Add a comment
Add your answer
Alex222 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 89
