跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Pentalobe screws just spinning!
Hello
Recently repaired a friends iPhones 5s. Initially was getting no service after repair and updating iOS appeared to resolve. Then phone died when testing, though all appeared okay so popped on charge.
After changing, received the reboot and blue screen of death. Attempted to update iOS via iTunes to no avail.
Assume two of the screws on the top right panel are wrong way round. Problem is the two pentalobe screws now won't come out - they're just spinning in place! I'm relatively sure that if we got those back out we could swap the screws back and all would be fine but just stuck at this point.
Has anyone had any similar problems with the pentalobes and if so, what did you do? Not keen on drilling as never done before but might have to at this rate!
Thanks in advance for any advice!
Cheers, J.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Hi Dc
Thanks for the response! In upward pressure, do you mean away from the screen? Sorry just wanted to clarify!
Thanks, J.
完成的
Yes upward pressure on the screen, so if the phone was flat on a table pulling straight up on the screen with the suction cup, and that will allow those screws to come out.
完成的
添加一条评论
1个答案
最有帮助的答案
I've seen this in the past, you need to apply upward pressure on the screen. Using a suction cup pull up on the screen and then try to turn those screws out.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jake 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,122
