跳转到主内容
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 个问题 查看全部
Do I really need a new logic board? (Water damage)
MacBook Pro 13" late 2014
Hi there,
Long story short- my MacBook Pro met with a pint of beer on the keyboard. Tried to dry it out, but the screen is now always black. It works fine when connected to an external screen, and all other components but the screen seem OK (keyboard, trackpad, backlight on keyboard, sound, webcam, etc). The screen also worked initially for a few seconds/minutes upon start up but not for the last few months.
I took it to a local repair shop to have a diagnostic done, and was quoted a LOT, saying the screen, keyboard, and logic board would need replacing. I just want to know if considering everything seems to be working apart from the display, if a logic board would really need replacing.
If yes then that's fine but I just want to make sure they've inspected it properly and aren't trying to hoodwink me as I clearly know nothing about computers!
Thanks very much,
M
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
First thing to do is hook it up to an external monitor and see if you get a good picture. Did the beer enter through the keyboard? Do all the keys work?
这个答案有帮助吗?
得分 1
3条评论:
Hi there, thanks for replying. Yeah, the beer was spilled on the keyboard, but everything but the screen works. Keyboard, trackpad, sound- even the webcam still takes photos. Attaching it to an external screen shows it works perfectly and appears to be isolated to the mac screen. Thanks!
完成的
Open it up and check it for corrosion, especially around the LDVS (video card connector.) Next I would try just replacing the the display. This machine is very well protected from keyboard spills. I am surprised that all the keys work. You must have not turned it on while still wet. I think you have a good chance of getting out of this relatively cheap. Also if all this work does have to be done, it may be covered under your home owners or renters insurance.
Here's how to do it: MacBook Pro 13" Retina Display Mid 2014 Display Assembly Replacement
here's the part: MacBook Pro 13" Retina (Late 2013-Mid 2014) Display Assembly
完成的
Thanks very much for the reply and advice, I really appreciate it. There diagnostic service I sent it too said I'd need to replace the logic board, keyboard and display (repairs then costing more than a new MacBook) so I'll definitely give this a shot. Thanks!
完成的
添加一条评论
添加你的答案
melissa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 247
