跳转到主内容
How to open the chassis in order to clean the fans?
I just need to know the proper way to open up the chassis of any laptop from the Vaio F series in order to be able to clean the fans. THANK YOU.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个回答
最有帮助的答案
Here a teardown video on a Sony F series laptop. It shows fan cleaning and heat sink replacement.
https://www.youtube.com/watch?v=lCAP9DpC...
这个答案有帮助吗?
得分 2
添加一条评论
First, remove the battery (& unplug anything of course).
Next, there are a good number of screws on the back you will need to remove:
- 1 on RAM access panel (marked with 1 dot)
- 2 on HDD access panel (marked with 2 dots)
- 2 retaining optical drive (marked with 3 dots), remove optical drive as well, slides out.
- 2 retaining HDD, accessible with HDD access panel removed, remove HDD as well.
- 4 under battery
- 3 under optical drive
- 11 around case (6 near hinges, 1 forward of battery, 1 near RAM, 1 near VGA port, 1 near S400 port, 1 under rubber cap near SD card reader).
Once battery, all screws, HDD, & optical drive are removed, pull bottom shell off carefully. Start from the optical drive side & pull up. There are clips on the front edge near the SD card reader. As you lift, pull the front edge of the panel forward lightly to release from the laptop. Once this releases, you'll need to slide the panel off of the VGA & HDMI connectors.
This will give you direct access to the fan & heatsink You should be able to clean the fan without removing from the motherboard.
Optionally, it may be worth replacing the thermal paste while you have it open. Just remove any screws around the heatsink, gpu block, & cpu block, & disconnect the fan cable. This will come out as a single unit. You can then clean the heatsink more easily, & use small amounts of isopropyl alcohol to clean the old thermal paste off the gpu & cpu blocks & dies. I used Phanteks PH-NDC thermal compound to replace it, but you can use any decent thermal compound you have available. Just put a pea sized amount on each die, & reinstall the heatsink assembly. Don't forget to reconnect your fan cable.
While you're in there, it's a good time to upgrade to wireless AC as well if you want. I used an Intel 7260.HMWWB.R model.
When you're done & ready to reassemble, just reverse the disassembly instructions. Note, you may need to lift the HDMI port slightly to slide the cover back over it. Otherwise, it's just putting the right screws back where they came from.
I will be replacing the keyboard on this laptop in the next week. I will try to take pictures during the process, as it should cover most of what I discussed here.
Update:
I didn’t have time to take the photos I had originally planned. I do couple that I took from when I replaced the thermal paste. They’re a bit blurry, but that’s what I have for now.
这个答案有帮助吗?
得分 2
评论:
Did you take the pictures? Are they posted? I'm reviving my old FW520 and ... well. Pictures would help.
完成的
Sadly, I was in a hurry when I finally got to it, & forgot. I have a few from replacing the thermal paste, but the wide shots are blurry & may not help much. I'll edit my post to include them anyways.
完成的
添加一条评论
添加你的答案
murtadha ameen 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 14
总计 2,895
