跳转到主内容
Solutions to fix common problems with the Durofix RV332 Cordless Li-ion Screwdriver.
6 个问题 查看全部
What is the polarity of this screwdriver and positive or negative
what is the polarity of this screw driver...a positive or negative...lost the adapter and purchase a universal ac adapter...butI need the polarity inorder to recharge...can you help????
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
已选择的解决方案
While there is a 90% chance that the outer sleeve is negative, to be sure you might go on Amazon and ask the question of one of the reviewers that bought an adapter for it. If they have a volt meter they can tell you.
https://www.amazon.com/Durofix-10730378-...
这个答案有帮助吗?
得分 1
添加一条评论
Got one at an estate sale and took a chance charging it with positive tip and it worked. I used 4.5 vdc @ 500 mah with positive tip and it took about an hour.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
sunnie1948 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 11
总计 529
