I tried to root my phone now it won't turn on period
I am able to get into the reboot screen and into the downloading screen but I cannot get into the actual phone don't know what to do can you guys help
Hi
download a official rom from the site ..and install it back to normal..then try again!
http://www.youmobile.org/blogs/entry/-Fi...
Ray
这个答案有帮助吗?
Download Samsung Smart Switch. Once installed, on top of the tab you will find a "more" option. The first option would be to process an "emergency software recovery".
这个答案有帮助吗?
How to root of galaxy core prime g361h
这个答案有帮助吗?
just install king root app in your pc and you can do root process in your mobile
I have read so many posts on how to root my zte paragon phone and I still can't get it to root!! It says "Install blocked" error code #0x1516EA. ( I also checked to make sure the "unknown sources:" check box was checked ). The programs I used were: SecureSU zip, Root King, Official TWRP, bootleader and the bootleader unlocking app. And some how during all this, the homescreen on my phone went nuts for awhile just flickering and scrolling different pictures and wording and no matter what I did, nothing helped. It finally stopped on one particular screenshot which starts out half of the size of the screen and cascades smaller and smaller into the screen. I can use the phone somewhat, I have to slide all of the images together and then I can move it up or down to be able to read what is behind pile of"clutter", very annoying! Can anyone please help, whether it's one of my problems or all of them I would APPRECIATE any and all comments. (except rude or lewd comments, then you will be reported). Thank you!
Rooting on the android is equivalent of jailbreaking, a mean of unblock operating system so you can install unapproved apps, deleted unwanted bloatware, update the OS, replace the firmware, overclock (or underclock) the processor, customize anything and so on. Rooting on the Samsung galaxy S5 have 4 steps. First, you must download Android root app on the CH play or reputable websites. Download and install One Click Root onto your PC. And then, connect your device. Connect your Android to your computer using a standard USB cable. Next, enable USB debugging. Open “ Develop option” and enable USB debugging. Finally, Run one click root. Run one click root and let the software do the rest. Before rooting, you should uninstall priviate apps which has your personal informations such as bank apps, facebook,… in order to protect your information. After rooting, if the phone doesn’t turn on period, you can try restart the phone or recharge your phone or bring it to stores to repair.
这个答案有帮助吗?
Press and hold both the “Power” and “Volume Down” buttons. Do this for about 20 seconds or until the device restarts again. This will often clear the memory, and cause the device to start normally
这个答案有帮助吗?
Reboot Samsung phone
Step 1: Disconnect your Samsung phone by holding down the Power button, the Home button and the Volume Up button at the same time.
Step 2: Release the power button until the phone vibrates, keep pressing the rest of the buttons.
Step 3: After the Android Recovery screen appears, release the rest of the buttons.
Step 4: Use the volume up and down buttons to scroll and the power button to select Wipe Cache Partition.
Step 5: Select Reboot system now mode.
这个答案有帮助吗?
You should try doing it again by following these steps.
If these steps fail, you should take it to the customer service.
这个答案有帮助吗?
Guide: How to Recover Your Phone After a Failed Rooting Attempt
If you have tried to root your phone and it won't turn on at all, you may be feeling frustrated and worried. Don't panic! Here are some steps you can follow to recover your phone:
1, Check the battery: Make sure your phone has enough battery. Charge it for at least 30 minutes before proceeding.
2, Enter Recovery Mode: Press and hold the Power button and the Volume Down button together until your phone vibrates and enters Recovery Mode.
3, Factory Reset: In Recovery Mode, select the "Wipe data/factory reset" option. This will erase all data on your phone, so make sure you have backed up all important data before proceeding.
4, Reboot: Once the factory reset is complete, select "Reboot system now" to restart your phone.
5, Install Stock Firmware: If your phone still won't turn on after the factory reset, you may need to flash the stock firmware. You can find the firmware for your phone model on the manufacturer's website or other reliable sources. Follow the instructions carefully to flash the firmware onto your phone.
6, Seek professional help: If none of the above steps work, it's time to seek professional help. Contact the manufacturer or a trusted repair shop for assistance.
Thank for attention on my post.
这个答案有帮助吗?
1. Perform a Hard Reset:
Press and hold the Power button and the Volume Down button (or the specific key combination for your device) simultaneously for about 10-15 seconds.
This should force your phone to restart. If it doesn't, proceed to the next step.
2. Attempt Safe Mode Boot:
While the phone is off, press and hold the Power button until the device logo appears.
Once the logo appears, release the Power button and immediately press and hold the Volume Down button.
Keep holding the Volume Down button until the phone finishes booting up.
If your phone boots up successfully, it means that a third-party app or the root itself might be causing the issue. Uninstall any recently installed apps or revert the root process to see if that resolves the problem.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 3,058
4条评论
Probably the system software needs to be restored via Samsung Kies or downloaded firmware off Sammobile.
由 Ben 完成的
como reparar el imei que lo borre mi correo luisd9455@gmail.com
由 luis 完成的
you need to buy a new phone
由 vuminhnghex1 完成的
I suggest you take your phone to a service centre or contact the manufacturer's customer support for assistance.
由 vuminhnghex1 完成的
