跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
4095 个问题 查看全部
iPhone 5S bricked after battery replacement
I went to replace a battery on an iPhone 5S, it obviously should have been a simple replacement but i went to reassemble the phone and it was dead. I have replaced every component to find the issue, the lock button flex, charging cables, screen, different batteries... no avail. I believe it is a logic board issue but I have no idea which part or how to fix it.
Is there something that a faulty battery or battery replacement could do to brick a 5S?
Any help would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个回答
Try the original battery again.
这个答案有帮助吗?
得分 0
评论:
I tried the original battery and a battery from another 5S - neither did anything. The phone remained non-responsive to anything - not recognised when plugged into my Macbook either
完成的
Look closely at the logic board for missing components, had an iPhone 5c a while ago that was missing a tiny resistor and wouldn't show anything on the screen.
完成的
If I look carefully enough, should it be fairly obvious if there is a part missing? Will I need to take off some of those component shields?
完成的
i just had the same problem. replaced battery and device bricked. went back to original and can't keep it work again. when i try to turn it on, screen is black, but iTunes recognize it (it asking to unlock the device password, but i can't do it)
完成的
Yeah, see unfortunately the iPhone isn't even recognised when plugged in
完成的
显示更多的1条评论
添加一条评论
Check the LCD connections. I usually don't remove the screen when doing a replacement.
这个答案有帮助吗?
得分 0
添加一条评论
It's not unfathomable that a third party battery could damage a motherboard.
Why not try removing the board and placing in another 5s that you know works? It's the quickest way to eliminate other possibilities? Good luck
这个答案有帮助吗?
得分 0
评论:
I've done this, tried a new iPhone 5S housing which had components in. I think it must be a logic board issue, are there places that fix things like this?
完成的
No good news unfortunately... There are people / companies out there that will repair iPhone motherboards, but as you can't pinpoint the fault it could be an expensive experiment. Personally I'd probably sell the phone for spares and look at getting another one :(
完成的
添加一条评论
Hi, I had a similar problem with an A1533 where the battery completely died. Think it was caused by overheating as the front panel w/LCD was detached from its frame!! I jump started the battery using hooked pins and an external low current charger from an old defunct phone pack but had to take it out of the frame to get to them however this worked fine and phone starts/runs with battery at about 20%
The 5S and 5C batteries are very similar but not identical, even if it fits in the available space its connector is wrong.
You might have damaged it in the process so worth checking under a magnifier for bent or missing pins, or a cracked connector housing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Max Shepley 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 2
总计 863
