跳转到主内容
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60 个问题 查看全部
How can I remove the display connector from the motherboard?
I need to remove the motherboard but I dont know how can I remove the display connector.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Make sure you teardown your laptop first, take note every nuts that you want to open it. Until you reach the connection between screen and motherboard. The way to disconnect the cable is unlock it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mattia Scarton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 419
