跳转到主内容
Also known as the Moto G3—an Android smartphone released by Motorola in July 2015. It serves as an economical alternative to Motorola's flagship phones. Model XT1540 in the US, with dual-sim and "Turbo Edition" variants sold in other regions.
89 个问题 查看全部
Why is my phone not restarting?
In order to remove the "google search bar" from the home screen i went down to SETTINGS>APPS>GOOGLE NOW LAUNCHER and then i found it already disabled so i uninstalled updates and tried to clear everything and disable it completely. After when i was done with it, i disabled every google related apps and systems. on returning to the home screen , the home screen stopped functioning and i was not able to access any app. i swited off my phone and now it is not restarting.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
What are the indications, will it not even power on at all, or do it perform a "boot loop" where an animation just keeps running without end,...?
It sounds like you were overzealous in disabling Google apps, and may likely have disabled some system services and apps that are required to run. If you can't boot into Safe Mode, you may have to reboot into the bootloader and recovery (how will differ from one phone model to another) and perform a factory reset to default settings. You will lose some or all of your data on the phone when you so do.
I would not recommend disabling too many apps. If you don't want to use Google services, just don't sign in to a Google account. You can turn off certain Google account data from syncing by turning off sync in the Google account(s) screen. That way, for example, you can use Google Maps, but not sync any Gmail or Google Calendar information.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
riaekka71 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 103
