跳转到主内容
How to switch back Win7 Boot Manager to Win8/8.1 Boot Manager style?
I have dual booted my PC...First I've install Windows 10 and then Windows 7. So when I boot my PC, a nice blue Boot Manager was appearing and i have to select an OS. But I had to install easyBCD because the Boot Manager was not showing up and was booting directly in Windows 10. After that, I had my boot manager back again but unfortunately it became black and white.
I want to get the blue one like in windows 8/8.1/10. Help please. How do I revert back to the blue one.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
THANKS
the cmd code work
完成的
添加一条评论
2个答案
已选择的解决方案
Nevermind. I got the fix.
If anyone having this problem, try this :
Open command promp in win 8/8.1/10
By pressing window key + X then press A. This will open Windows PowerShell.
Then write the following command :
"bcdboot C:\Windows"
Press enter. Done.
Reboot to see changes.
这个答案有帮助吗?
得分 3
2条评论:
Thanks man, it worked for me too
完成的
Initially it consistently booted off the nice blue screen but after a few trials its back to the black coloured Windows Boot screen. I tried cold booting via power down command 'powerdown /p' but that too doesn't help. I also tried retyping command "bcdboot C:\Windows" but to no avail. How do I get back my favorite Blue booting screen ?
完成的
添加一条评论
Hi. Have you tried to look in system properties? Open the control panel, click the system and security option, click the system icon, and click advanced system settings at the left side of the window select the advanced tab and click the settings button under startup and recovery. There you can make your primary system windows 10 and it should write boot manager.
And also you can try msconfig (WIN+R and type msconfig)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rohan Lukhoo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 1,951
