跳转到主内容
雅达利视频电脑系统(VCS)有MOS科技的 6507 CPU ,频率为1.19MHz
32 个问题 查看全部
What are the screw sizes for the case?
It looks like the case has four screw holes and all the screws are missing. Mine is a sears tele-games console, but I think it's an exact clone of the 4-switch atari 2600. I'd like to know the screw sizes for the case so I can put this thing back together properly!
Update
Here are the exact screws I ended up using, in case anyone else needs the info. #6x3/4" from Lowes. Model #: 490198
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Give me a second, I'll dig out mine and take a picture of the screw for you.
完成的
添加一条评论
3个答案
已选择的解决方案
Here you go, it's about 3/4 Inches long. I put it next to an SD card for reference.
这个答案有帮助吗?
得分 1
1条评论:
And all 4 are the same
完成的
添加一条评论
I measured the screws on my 4-switch Woody and Vader.
The short answer is you need four screws of size #6-20 (aka #6) in length of 5/8”. Details below…
Quantity 2 #6-20, ¾” length screws are at front.
Quantity 2 #6-20, ⅝” length screws are angled at rear. They are installed at an angle, parallel with the silver switches.
I think you could use ⅝” long screws for all four locations but factory used longer ones up front.
Measured sizes to help folks convert to metric…
Diameter 0.136 inches
19.7 threads-per-inch
Length: 0.725 inches and 0.600 inches
这个答案有帮助吗?
得分 1
1条评论:
Thanks for confirming, just found this via brave browser search.
So for metric it will be M3.5 width (mine looked like 3mm but measured 3.4 so came here to confirm) .
For the Sixer consoles = 6 screws of 16mm (blunt tip) and 2 screws of 20mm (sharp tip).
The two 16mm screws in the middle of the console go with washers (these are part of the faraday cage securing from the outside, so leave those middle holes empty when working on cage)
If you find stainless steel screws, best to grease the ones that contact other metals, incase of bi metallic corrosion.
完成的
添加一条评论
Thanks man.. Heading to LOWES now!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris O 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 3,347
