跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone display dead spot after water damage
Hello, recently my iPhone 6 fell into a hot tub, and after a few days in rice, it has no damage except for an area of the touchscreen that is no longer functional, as shown in the picture. Any advice on how this could be fixed?
Update (06/14/2016)
Added pictures to clarify
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Further clarification, the lines come from me dragging my finger across the screen using the snapchat draw feature showing the area of the touchscreen that does not respond.
完成的
添加一条评论
3个答案
已选择的解决方案
Can you post a better picture of the screen with it on?
Update (06/14/2016)
Replace the screen. It sounds like a digitizer issue
这个答案有帮助吗?
得分 2
1条评论:
Posted, sorry if the black screen implied that it did not function.
完成的
添加一条评论
the connectors trap water that cannot be absorbed by rice. the trapped water is corroding the connector. there are 32 tiny connections. a few of them have already failed causing the dead spot. There is still a chance this can be fixed but time is of the essence. You need to have a repair shop do a water treatment program on the phone. this involves opening up the phone and using a special liquid to dislodge the water. you need special equipment to do this not unlike the equipment used to clean jewelry. you will then need to replace the screen assembly and connectors. hope this helps.
这个答案有帮助吗?
得分 1
2条评论:
It has been like this for about a month, the problem area has not grown or shrunk since then, do you still recommend this?
完成的
Mine has NO WATER damage and is like this down the middle.
完成的
添加一条评论
Unfortunately, looking at the pic you provided the screen is done. There is/was still water on the inside that the rice could not get at. This is what further damaged the iPhone.
Luckily you can replace the screen but, in my experience, you may experience other issues.
这个答案有帮助吗?
得分 0
4条评论:
See if the added pics clarify the situation, sorry if the black screen implied that the screen did not function.
完成的
Thanks for the clarification. If the area's in red are not working you will need to replace the screen.
完成的
The area that is not working is the strip in the center-left of the screen where I cannot draw any lines.
完成的
Hello, my iPhone6 is exactly the same down the middle, has been since I got it in 2015, and there is no water damage.
完成的
添加一条评论
添加你的答案
swishinj 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 10,851
