跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
How to see a motherboard problem
Hi
I've just changed my battery in my iphone 5 but after that, the new battery unload really fast.
So then l return to the place where l bought it and the saler said me it is a problem with the motherboard.
But now l would like to know how to recognise a motherboard because l feel like the saler didn't put a new battery but one that have been already used...
Thank you
Eric
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
it definitely sounds like a problem on the motherboard with a chip called Tristar or U2. The problem is that this chip is draining more power than what you can put into your phone. Therefore replacing the battery doesn't address the issue at hand.
This is definitely a replaceable part, and is a very common problem. go to a repair shop that does micro soldering and they should be able to help you out.
If you want to give it a go yourself ill point you in the right direction on what to do, but it requires a lot of expensive equipment and even more time learning how to do it.
So I wouldn't recommend doing it if you haven't done it before.
A motherboard is basically a PCB/Circuit board that is inside your phone with thousands of microscopic sized components soldered to it. There is no way to see a motherboard problem, only ways to diagnose a motherboard problem. Kinda the same way that you can't see DNA but you can diagnose problems with it.
My biggest issue is why the repair shop you first went to didn't see the problem in the first place (As it only takes 60 seconds to test for) and refer you else where. We get customers coming in all the time asking for battery replacements and only about 15% actually need them, the rest have the U2 Problem mentioned above.
I hope that answers all your questions.
Melanie
这个答案有帮助吗?
得分 2
1条评论:
Hi. I have the same issue. My phone also feels like it heats up. Also, if I press the power button and leave it on the table for about 3 minutes 30 seconds, it shuts down completely (and needs to be restarted). Could you guide me in the right direction because hte store I went to replaced the battery and couldn't fix the issue either? (iphone 5s in my case)
完成的
添加一条评论
Hey mate can you help me when i do record in the front camera and when i done then i review and the result is low sound i can’t really hear clearly the sounds not like in the rear camera just normal my problem is its just the front HD camera when i record please tell me if you know what is the issue
这个答案有帮助吗?
得分 0
1条评论:
Without more details like the model of phone you have, the only thing I can suggest is try cleaning the microphone ports on your phone
完成的
添加一条评论
添加你的答案
ericbuya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 6,995
