跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 个问题 查看全部
Is this burnt logic board damage localized or extensive?
This logic board had some minor localized water damage, after which one of the components sparked and burnt itself. I asked in a separate question for confirmation that the burnt component was a 220 Ohm inductor, and got a good answer.
Now I have some detailed magnified photos, and I wanted to ask if the experts can see if this is localized to just the component, or if anyone thinks just replacing that component will not be enough, or will not be a simple process now.
Since this is one component, and at the edge of the board I feel confident doing it myself, but I'm not sure what the other circles near the component (see the photos of the same board in good condition for comparison) are from and the burn damage looks like it covers those too.
Any advice would be greatly appreciated. Thanks...
Magnified comparison of damaged board and good board:
Damaged board (that is the only moisture tag on the board that went red):
Good board:
Board diagram area:
Component on Schematic:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
It appears to me that if you replace that inductor( I think it's actually a ferrite bead type of inductor), you will have a working computer. The chip at the other end of the lcd connector looks a little crusty, I'm not sure if you will have problems with it or not. I think you have the wrong board view though. It has components that aren't on your board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Peter Miller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 110
