跳转到主内容
微软第三代Xbox游戏机于2013年11月22日发布。
727 个问题 查看全部
there is a network problem.Replaced the wifi nic card and it persist?
i bought a wifi nic card for the xbox one. replaced my old non working card but i still get the "there is a hardware problem" when trying to set my xbox up. i reset the xbox so i dont know if there is a way to bypass the start up screen.
I really want this to work.
before resetting the console i was able to use ethernet. now i cant use any of it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I've had the same problem. In one I repaired the RF rol board was bad. Another one the customer had tried to repair and where the Wifi antenna plugged into the RF board was pulled loose.
Also make sure the WiFi card and the cable connection to the Mobo are pushed in all the way.
Hope you have already figured it out, please let me know if you did and what you did to repair it.
这个答案有帮助吗?
得分 0
1条评论:
I replaced both the rf rol board and wifi board and no difference. While i had it opened the second time i had fully disassembled it and everything was plugged in properly but no go on any of it. Ended up just getting rid of it on ebay and picking up another xbox on ebay.
完成的
添加一条评论
添加你的答案
Nicholas Everett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 195
