跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
iPhone 5c dead after re-installing the large emi shield
I replaced the u2 IC because the phone wouldn't charge unless the phone was on. I tested it after the replacement, and it worked perfectly! I then put the emi shield back on and now it won't boot. :( No apple logo, no backlight, no sounds, and it's not detected by the computer. It draws 0.08 amps of current now, and before replacing the tristar chip it drew 0.02 amps until the phone was turned on. I removed the shield but there's still no power. The microscope doesn't bring anything to light either. Every line of power that I can identify has the right voltage except for one, the 1.8 volt line to the cpu has 1.6 volts, but I don't see anything that could be drawing it down. Battery voltage is 4.2 volts, and vcc main is the same as the battery voltage whether it is 3.8 or 4.2 volts. The speaker amp chip was getting up to 108° F until I removed it, even with just the battery connected. Is there anything else I should be checking?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Josiah,
You might want to check on step 12 of this manual. I was wondering if the screws were screwed in the right hole(s).
Steffen
这个答案有帮助吗?
得分 1
2条评论:
I never even put those screws in. I know not to put them in the wrong spots anyway. A very hard learned lesson, the one that got me into board repair in the first place. Thanks for the suggestion though.
With the 5S, long screw damage causes a blue screen and reboot after an extended apple logo. Do you know if it's the same with the 5c? I'm not about to try it. LOL
完成的
Hi Joshia, I am not familiar with the 5c, so I am afraid I cannot answer this question.
完成的
添加一条评论
添加你的答案
Josiah 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 135
