跳转到主内容
加入维修社区 - 创建账户
Support for percolators manufactured by Farberware.
My percolator is not heating
My percolator does not heat at all. When I connect it, the water remains cool. The base becomes very hot after some time, but does not heat the water. Does anyone know what is wrong with it, and how to fix it? I have a Farberware millenium percolator, model fcp240.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I have FCP 240-A model that stopped heating. How do you take it apart? The bottom screw comes off easily but the there seems to be a bolt inside the pot that needs to come off. I can get leverage with a wrench. Suggestions?
完成的
添加一条评论
3个答案
最有帮助的答案
@nadeshko could be a thermostat as well as a heating element issue. time to take it apart and inspect. Take a look at this video for an idea of what to look for. If in doubt take plenty of pictures and post those with your question. Use this guide for that.
这个答案有帮助吗?
得分 1
添加一条评论
If your Farberware percolator is not heating up, there may be an issue with the heating element or thermostat. Check to make sure they are clean and free of any mineral deposits. If they are damaged, they may need to be replaced.
Another possible issue is the power cord. Make sure it is securely plugged in and that the outlet is working. If the power cord is damaged, it may need to be replaced.
For more information kitchenzap.com
这个答案有帮助吗?
得分 0
添加一条评论
My percolator does not connect to electricity
这个答案有帮助吗?
得分 0
1条评论:
@patrobus not enough information here give us more details. What do you mean it does not connect to electricity? Give us more of a description
完成的
添加一条评论
添加你的答案
Andrea Garcia 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 29
总计 5,372
