Why is it having trouble moving in reverse?
My car has trouble moving in reverse. Whenever I have to back up, it seems like the gears are just not engaging fully or something like that. It's an automatic transmission. It's gotten so bad that when I park my car, I have to make sure that I don't have to reverse up a hill to get out. I almost have to push the gas pedal down all the way to back up even a small incline. Any ideas as too what might be causing this?
22条评论
Sounds like a dying transmission to me, but I'm not an expert.
由 Kyle Wiens 完成的
Do you have the same problem in forward, such as the car taking a long time to engage gears? Your clutch could be slipping.
由 David Hodson 完成的
I don't gave the same issue in forward.
由 Scott Head 完成的
i have a 1991 model of Nissan Maxima...it doesn't revers so i changed the new old gear to a new one hoping that it gonna work...but the problem persisted...what am i suppose to do??
由 James 完成的
your transmission is slipping, this happened to me so I know from experience. its just a matter of time
由 ryancalero 完成的
显示更多的17条评论
