跳转到主内容
Released July 2012 by Fuhu, Inc. Model Number: NABI2-NV7A.
37 个问题 查看全部
Can't log in mommy mode
Trying to log in mommy mode, keeps saying invalid password. Password is correct. Can log into the account from my phone but can't from nabi
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 32
11条评论
I push the + volume then power nothing happens. So i push - then power a reboot pops up but i can't click on anything. Then a dead Android pops up.
完成的
This is still an issue, right now I keep getting the "not enough space to download item, ask Dad to clear space". If I close out that message it prompts me to log into Dad mode. If I close that prompt then it goes back to the not enough space message, it's a never ending cycle that won't go away!
When I try to login, it keeps telling me I have the wrong password, it is NOT. I've tried both the nabi password that I can log into the website just fine with...and I've tried the google password associated with the email with the account. I'm 100% I'm entering both correctly. When I try to reset the password from the tablet it also will not let me, just keeps saying it can't find my info.
As of now the tablet is useless and were leaving for a 15 hour road trip tonight! This is very VERY not cool! I can't get on to see if it's actually logging into Wifi, can't get on to free space, and I've reset it numerous times and it STILL keeps telling me it's trying to download something.
Furthermore, when I do the volume up and power buttons to factory rest, it only gives me three options.... Recover, fast, and normal boot. With recovery it just goes to another screen with the android logo opened up being worked on, then it just loads normally...and STILL pops up with the %#*@ download message and STILL won't accept my password...
完成的
I'm having the same problem and it was right before my son's first plane ride. I bought it to keep him busy and I never packed any other toys. That was a a LONG 3 hour plane ride with a 18 month old.
完成的
Did you see the answer about turning off WiFi?
完成的
Did y’all get an answer? I am having same problem and and first plane rides for kids is Monday!!!! I need help and feel like it’s just a piece of trash now
完成的
显示更多的6条评论
添加一条评论
9个答案
已选择的解决方案
I had this problem, it appears that the Nabi servers are down (maybe permanantly?)
To enter mommy or daddy mode though, turn off the wifi - you can either do this in the settings (within the kids mode) or its easier to just put it into airplane mode (hold down the power button and there should be an option there)
Or go somewhere where there isn't any wifi
Then log in to mommy mode as normal
It would seem that if the tablet is connected to wifi, it checks the password on the internet, and seeing as there is a problem it returns an error.
I imagine though that you might not be able to change the password as currently you can't log into the Nabi account via the Nabi website.
这个答案有帮助吗?
得分 25
15条评论:
Thanks! Worked for me!
完成的
I forget my mommy mode password,so I can't get in.
完成的
Thank you! It worked
完成的
Worked great thank you!!!
完成的
Thank u it worked for us why is nabi tablets not taking the passwords it worked when we turned off the wifi
完成的
显示更多的10条评论
添加一条评论
Power down the nabi and wait 30 seconds and turn back on and try to log in as mommy mode. If that doesn't work then do a factor reset.
Remember doing a factor reset will wipe your nabi completely to factory new which will loss all your pictures and apps (unless you backed it up).
"Press the Volume + Button first, then press the Power Button and hold them both until the system menu appears on the upper left corner of the screen. 3. Use the Volume – Button to highlight “Wipe Data/Factory Reset,” then press the Power Button to select It. "
这个答案有帮助吗?
得分 6
4条评论:
I've tried that 3times to set the factory reset but all it sucseeds to do shut it down.
完成的
@rickbeau I got a answer! Turn off WiFi on kid mode and try that! Wish you best of luck!
完成的
It didn't work at all
完成的
My tab is not download any things
完成的
添加一条评论
I got a solution! Turn your WiFi off on kid mode and try to sign in! Worked for me! Wish you best of luck Danielle!
这个答案有帮助吗?
得分 4
3条评论:
I can't even access my WiFi settings I'm literally locked out of my good games, all of my games on kids mode were supposed to be for my nephew.
完成的
I am Actually MoonWolfie just on a diffrent account,Anyone need help?
完成的
I keep trying to sign in and it won't work
完成的
添加一条评论
I was unable reset my password and had a hard time finding out how to reset the tablet. This video is most helpful!!!
https://youtu.be/T-bamfAKvgk
这个答案有帮助吗?
得分 3
2条评论:
I like it
Thanks for making it
完成的
OK thanks this is so helpfulness
完成的
添加一条评论
what happen im done to reset but never change the apps and i cant use it because nabi tablet need password
这个答案有帮助吗?
得分 2
1条评论:
what will i do this tablet im done to reset but never changing
完成的
添加一条评论
I did the factory reset it still is asking for last Google acct which I don't know bc its second hand please help
这个答案有帮助吗?
得分 2
2条评论:
What do I do to get in to the nabi se
完成的
If you do a factory reset with someone else's Google account still on there the tablet will "Google Lock" meaning you can't do ANYTHING with it unless you know the other Google account info. Google Lock basically means bricked tablet. Sell it on eBay for parts or trash it.
完成的
添加一条评论
i think i need a new idad
这个答案有帮助吗?
得分 0
添加一条评论
I cannot even open my settings I need help with this, I also cannot open my 3 little lines, it tells me they are open but they are
这个答案有帮助吗?
得分 0
1条评论:
I reset the tablet and I can't log in now
完成的
添加一条评论
It said I need to sign in owner
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Danielle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 62
总计 48,576
