850 EVO 120 GB SSD can't mount
I need some help,
I purchased a 850 EVO SSD which I can format externally using a thunderbolt case. I formatted it: Mac journal/partition1/GUID base for Mac but when I put the SSD inside my system the disk was not formatted properly so I can't install a fresh copy of the OS.
I need some help pls
4条评论
Can you give us the full serial number of your system or better yet see if you can correctly identify which model series your system is using EveryMac then tell us what you have.
Sadly there are a few different versions of the 13" MacBook which is why we need to know what you have.
由 Dan 完成的
Your systems specs: MacBook Pro 13" 2.5 GHz i5" (Mid-2012)
由 Dan 完成的
@lola - Here's how to post things: Technique: Adding images to an existing question
由 Dan 完成的
Thx to all the support from the community . I’m back by the way just finish my study.
Regards
lola/Tod
由 Tod 完成的
