这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4638 个问题 查看全部
iPhone 6 says " No service " or "searching"
I can not get my phone to get any cellular signal. I have tried everything on the software side of things and I mean everything. I know this is a hardware issue because for a while If I just gave my phone a bump, the cellular connection would come back on and I would have service. I dove into the phone and I disconnected all the cables that plugs into the logic board and even cleaned the logic board. I connected everything back on, still no service. I need some help and answers on what I should do to get this working on my own. It's got to be something simple. is it a simple process to replace the cellular antenna and if so where can I purchase? Could it be the RF antenna switch ?
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 5
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
3个回答
Here is a guide. Hope to help you: HOW TO FIX YOUR IPHONE CONSTANTLY SEARCHING SIGNAL PROBLEM
这个答案有帮助吗?
按维修分数 0
评论:
I want to thank you for you reply but yes I have tried this.
添加一条评论
Check the date and time. If the date and time are off, it'll cause this issue. I fixed an iPhone 5s that was set to 2027 that was constantly searching. I hope this helps.
这个答案有帮助吗?
按维修分数 0
评论:
Thank you but I have tried this
Bummer. Have you tried getting a new sim card yet?
添加一条评论
Is there any update on this issue? I have the same problem and I know the problem is on the motherboard. It was bent before and probably the solder underneath one of the chip is not connected. Is anybody knows which chip is responsible for carrier network?
这个答案有帮助吗?
按维修分数 0
评论:
The baseband chip is responsible.
But...I don't think this is hardware. I can't prove it with data, only my personal observations. I took the initial iOS10 download on my iPhone 6 and I missed almost every single text and email while I was traveling for a whole week. When I got back home, iOS updated again because of known network issues. I took that update and still had massive issues with data and texts.
I switched over to another phone since I didn't have the patience to deal with it. Chances are setting it up as a new phone in iTunes would fix the issue. But...I can't say 100% because I gave up.
I honestly don't think there is a solution to this unless you know how to solder motherboard chips. I found several videos where they would solder off the bad network chip and put on a new one and that fixes the issue. I gave up on trying to repair this and just use the phone as an iPod. Sorry for the bad news.
添加一条评论
添加你的答案
James srun 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 6
过去的30天: 22
总计 11,952
