跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Phone won't turn on and Error 4014
Hi there,
This second hand iPhone 6 I purchased is not turning on at all, and when plugged into iTunes it doesn't vibrate or show any indication of life, but then shows an Error 4014 when trying to restore. I believe the phone is in recovery mode because it will not turn on or show any sign of working.
I thought it may have something to do with the inside of the phone, so I opened it up and saw that the battery was slight swollen and smelt of chemicals (nail-polish/fruity type smell).
My question is are these two issues related, and if I get the battery repaired, should I expect to be able to repair the error 4014?
Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
It's definitely worth a try. Battery shouldn't cost too much.
完成的
添加一条评论
2个答案
最有帮助的答案
I would try replacing the battery.. but i would first unplug the battery and plug it into the wall outlet and see if there is any sighs of life.. problem could be more then a battery
这个答案有帮助吗?
得分 1
1条评论:
Good idea. Will try that soon.
Thanks
完成的
添加一条评论
its fixit and texted . SEE here photo after solved. this Error Solution Not Easy Remove and fix . Error 40 ,4013 , 4014 , 9 all same solution
1) fast remove nand carefully because you need sn /bt/wifi address from nand.
2) repair nand with any repair tool
3) back nand in motherbord and restore full
4) done .
this work dont this to Easy . thanks
Done Error 40 ,4013 , 4014 ,9
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Zac Webb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 902
