跳转到主内容
Device repair and troubleshooting for the 7" RCA tablet released in 2014, identified by model number RCT6773W22.
129 个问题 查看全部
tablet comes on, but dose not work it's frozen
my tablet want do anything but come on. what to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
14条评论:
Have you tried a factory reset?
完成的
How do you do a factory reset? The tablet is frozen at the power up screen. I can't get it to shut off or anything
完成的
My exam 7 voyager will not turn on even after trying to do the factory reset and tried the hard reset and nothing happens when I hold the power and Vol + buttons and after a minute and a half still nothing on screen. When I put it on the charger it flashes repeatedly. I left the tablet on charger and after 5 mins I saw the white screen with "RCA powered by android " with dogs on it then flashes back to the black screen with battery icon next to orange triangle with a red exclamation mark. Should I try letting it stay on. Charger or anyone know any other suggestions??
完成的
Hi @sicilia24 ,
Try leaving the charger connected for 1-2 hours to see if this "kickstarts" the battery back into charging.
Sometimes when a battery has been depleted too far it goes into a self protection mode and needs time to be "woken up" so to speak.
If it does start charging again, allow it to fully charge before attempting to use the tablet.
Also after this, initially do not allow the battery to fall below 30-40% charge before recharging until you get to know how long a charge lasts. It may be that the battery is beginning to fail anyway. Even rechargeable batteries have a lifespan.
完成的
Why does my tablet come on then after a few things it goes blank and back to the white screen with the puppy dog in it and then some times it comes on and do a few things on it and it'll freeze up and you have to push that reset button again
完成的
显示更多的9条评论
添加一条评论
1个答案
use dfu mode to do a hard reset,try search your device dfu mode in google ,you may find the answer
这个答案有帮助吗?
得分 0
2条评论:
DFU mode is only on apple devices
完成的
So what do i do? Idk what model it is or whatever but its a regular blue one but it says its charging when i first plug it up but its not charging and it goes on the screen with Nipper and Chipper and then it shuts back off to a black screen is it crashed or can it be fixed? Any tips?
完成的
添加一条评论
添加你的答案
saria 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,246
